very intersting Paul
Not overly confident that it is G pfeifferi, but I can see why you've gone that way.
Personally not seen G pfeifferi fruiting on Pear and the Fungal Record Data Base has it almost exclusively on Beech across its 288 records with 7 on Oak, 1 on Willow & 1 on Lime.
How accurate these records are is open to debate I guess.
British Fungi - record details
Can you take a wedge slice showing the flesh & tubes ?
whats going on with the bark plates to the side & above the bracket?
Older attachement point of a bigger bracket perhaps?
Thanks David. Yes, I assumed that the discolouration on the bark above was from the site of a previous bracket that has been knocked off.
Unfortunately I can't take a slice as the tree is not local to me (I must start carrying a sharp knife in my survey kit bag).
I did also wonder if it could be a Phellinus species as it's on Rosaceae?
Have you seen it on Pear before then Tony?
seen australe on most things, even conifers like larch and applanatum also.
|For what it's worth (not very much, probably) I thought is was an arrested Phellinus pomaceus.
That is also a distinct possibility but would expect it to have a more slanted pore layer:thumbup1:
