Ah nivver even know they existed!
A Cat Challenger based bit of Kit I suspect
The "Combat Engineer Tractor" was more my vintage.
Some o them for sale as well.
Without the solid rocket propelled Anchor for the winch rope unfortunately.
Werry werry handy for winching oneself up a hostile held riverbank.
There was a article in the forestry journal a while ago with the exact same machine I think following a small harvester think it was owned by a small tree firm.
Thats an Oxtrac. A friend had one of these, very good for small scale thinning extraction, he used a small forwarder trailer with it. He did a tree surgery job with me once we towed the chipper to the bottom of the garden and pulled a bunch of Leylandii down in no time. However it didn't really work out quick enough for most of the the forestry work he did and he used to hire in a tractor
Sent from my GT-I9300 using Arbtalk mobile app
Yep they're pricey and not perfect.
Weak points - track stretch / maintenance,thin winch cable for power of machineleand easy to pull a track of when screwing round on the spot.
Strong points - can operate in places that similar size/power tractors would die in, go to/from site behind pick up, very low ground pressure (sub 7 psi )
hydraulic outlets running at 50 L per min / 180 bar, runs on less than 30L fuel for 8hrs on the clock,
Sent using my finger.
Read more
