Just had a Stihl TS480i fuel injected disc cutter in today , as usual the owner says "nothing wrong with it just needs a service" LOL
Had a quick play with it tonight , once i got the pull start to actually engage with the engine it felt tight even with the decomp pressed , took of pull start and turned engine by hand felt really notchy almost like when the magnets pass the coil but rythmically throughout a full rotation of the crank, took the other side off to look at the flywheel & there is no coil visible !! so i assume this must be under the flywheel ??
So i am wondering is this the rythmic resistance i feel when rotating the engine or is it something more sinister :confused1:
I guess it wouldn't start for you?
