Transit Beavertail rear tyre Pressures
Matthew Arnold
I have searched high and low for the tyre pressures on a 58 plate transit beavertail but cant find any. I would put 10psi under the maximum normally but as it is dual wheel and has a wacking gurt mower on the back i'm not so sure. What do the transit arbwagons have on the rear?
It should be on a label on the driver's door jamb.
I cannot check one atm but its 67psi on front and 44 on back IIRC for 195r75c16 on a 350
