Broken 201t tank
_tc
In short, you need to remove the recoil cover, clutch cover, remove the carb, remove the top handle, remove the cover directly under where the top handle is, remove the manifold - note the different lengths of the retaining screws - get then the wrong way round and you will know it:thumbdown: Can't remember if you must remove the clutch and inner covers or not.
You should then be able to remove the tank and do the reverse of the above.
It is simple if you take it slowly and are reasonably mechanically minded - take a few pictures of the saw as you take it appart to jog your memory on reassembly.
spud did you get the PM i sent
