New Ms192t
PHAS
Jack, it feels like I've got an old friend back! Lovely little saw with a big punch.
As for the modding, it's purely opening up the can.
I'm going purely from memory so bare with me if I slip up! Lol!
Firstly remove the screw(s) holding the deflector plate over the outlet of the exhaust can. If there's a spark screen under it, take that out and attach it to a 3 foot cane with a bit of duct tape. This will work as a micro fly swatter, or mozzie swipe, much more useful than it's designed use.
Then you should be presented with a recess with the outlet hole in it. Get a drill, around 7-8mm, and drill several holes in the back of the recess. The idea is to make this rectangular recess into one big hole, so once there's plenty of the tin drilled i simply got a chain file and honed out the remaining metal and made good.
Then, screw the deflector plate back on, refit clutch cover, start, and reset carb. It's likely it'll only need a tad out on the high screw.
Just in case your in any doubt, there's no going back unless you buy a new can, so you've been warned IT WILL BE LOUDER THAN IT WAS!!!!
It will transform the saw though, and in my opinion not be too far behind the power of a 200, it would be a close contender for a 540 and yes, it will pull the pants off a 201. All this from a 3kg saw.
Once done, you may also be lucky enough to have the most retro fly swat and be the envy of all your mates.
  • Replies 21
Love my 192t! would like to hear your mods 18 stoner.
As NFG said available here in France, 380 euros otab.
Yep, pinged one in M Bricolage at the weekend for 389 euros, gave me an excuse to chat to the rather attractive sales girl :blushing:
N
