Hi all what's the cost on the 550xp on a 15" bar thanks Jon
Jon, I think it's worth spending the little extra on the XPG heated handle version :thumbup: cheers, steve
Currently On FRJones
550XP on 15" bar is £543.76
550xpg on 15" bar is £581.24
Edited by SteveA
  • Replies 80
HI STEVE thanks mate jon i will ring JUSTIN THEN THANKS JON :thumbup:
No worries Jon, apparently the Husky bars are a bit on the soft side, wear out fairly quick. You may want to consider a Sugihara bar for the long term. I'll be ordering a 15" Sugihara Pro when mine wears out.
I also got an 18" Sugihara Light type Pro bar from Rob at ChainsawBars (the one with resin infilled to reduce the weight). Decided to go with the resin bar as wanted the saw to feel as balanced as possible.
Hope this helps, cheers steve
HI STEVE thanks mate Jon i will ring JUSTIN THEN THANKS JON :thumbup:
Sugi bar as well then Jon, is it your birthday?
N
Looks a nice saw might treat myself if my old 346xpg sells on the bay,
My Sugi bar for my best 346xpg lasted two weeks before it bent, thought they were indestructible?
Hopefully jones are sending me a replacement so will try that
How much do you want for your 346xpg?
Thanks
The Sugihara bars aren't described as being indestructible but from what I can gather they are supposed to last much longer when compared with other bars.
Which Sugihara did you have on the 346xpg? Was it the resin one, or solid?.... ....and what happened for it to bend so soon, did you get it caught up?
Cheers, Steve
