Safe to say I had a great day!! Hard work, but worth the toil. Not sure what everyone else thinks of the results but I am well chuffed considering I pretty much had no idea what to do! Thanks to people on here who post things about milling, I learned all I needed to discover an addictive new hobby! Cheers
Ok cool, i wasn't sure if the stickering was right? What's the best thickness do you think? I did three butt's in 1.5 days. So not all that productive time wise but definitely faster now as I really did make it up!!! The first cut took me a long time to set up and I'm sure there must be a better way than how I bodged it! But it turned out pretty good anyhoo. Thanks. I'll go again tomorrow and post more pics
I'd go about 25mm for your sticks and try to use the same wood and the timber you are stacking to minimise any grain staining.
Looks like you got the hang of it though, cracking job mate.
Brilliant. Thanks for all the advice! I've saved the biggest straightest piece for tomorrow. I want to cut it into actual boards, if you catch my drift? Rather than through and through, I've seen a vid where they cut the top cut then the bottom cut, then a new top cut to create 3 flat sides!! Then through and through, creating boards. God knows how you make it square! I'll show you how it went tomorrow! Cheers again
