Help
case mx270
We got our new Makita 9010 saw yesterday today's the first time I ve started it with in seconds I had chain oil pouring everywhere have tried to turn flow down but not sure how far to go and if I turn it right down will the oil flow stop altogether? Never had a saw with adjustable oil flow before ! Thanks
I would not have thought it would shut off completely if done up , I would assume this would be the minimum output , does the handbook indicate different settings for different length bars ??
Sent from my iPhone using Tapatalk
Hi no handbook not very helpful I was really surprised about how much was pouring out I ve turned it down loads could go 2 or 3 more turns
...I ve started it with in seconds I had chain oil pouring everywhere...
What do you mean by pouring everywhere? Is it pouring out from parts other than the hole where it should pour out from.
Was the correct bar and chain installed?
It's a big saw that 'houses' big bars and chains. Big saws use lots of oil to lube those long bars.
Wolter
Wolter
Its pouring out of correct hole when running on a few revs but its not getting down bar just running on to floor. Correct bar installed by dealer.
Right tried saw tonight cut 4 big pieces of wood put it down on floor and on tick over it was pumping a pool of chain oil out from under the chain cover, we ve turned the flow down a lot but don't want to reduce it more because can see the bar is getting hot.I ve checked the bar and its the right bar.
Sounds like you have the wrong bar possibly ? The oil hole outlet not in line with the hole in the bar ? Or the pump outlet connection not secured properly .....?
