Bio chainsaw Oil: Oregon Arborol Plus
Just found a thread on which oil people are using, started v recently. I would post a link if I knew how (combination of new app and iOS me thinks?)
  • Replies 20
... combination of new app and iOS me thinks?)
corylus
•Tap the three dots in the upper right corner of the screen
•Select 'Web View' - Arbtalk then opens directly into a non-app view of Arbtalk
•Search for the thread you're interested in and when you've found the correct one, scroll to the head of the page
•Once at the top, highlight the page's URL and opt for 'Select All'. Now opt for 'Copy', which will copy the entire URL belonging to that thread
•Now go back to the app version of Arbtalk by pressing your iPad/iPhone/iPod's menu button and opening the Arbtalk app - you'll enter where you left off in the same thread as before, from where you can 'Paste' the copied link, (URL) into your own post
Edited by TGB
corylus
1. Tap the three dots in the upper right corner of the screen
2. Select 'Web View' - Arbtalk then opens directly into a non-app view of Arbtalk
3. Search for the thread you're interested in and when you've found the correct one, scroll to the head of the page
4. Once at the top, highlight the page's URL and opt for 'Select All'. Now opt for 'Copy', which will copy the entire URL belonging to that thread
5. Now go back to the app version of Arbtalk by pressing your iPad/iPhone/iPod's menu button and opening the Arbtalk app - you'll enter where you left off in the same thread as before, from where you can 'Paste' the copied link, (URL) into your own post
Sorry! Got that in the wrong order. Steps 1 and 3 are mixed up.
Should have been:
1. Within the app version of Arbtalk, search for the thread you're interested in
2. When you've found it - then tap the three dots in the upper right corner. Arbtalk opens in a non-app view of Arbtalk
3. Scroll to top of page and highlight the entire URL
4. Opt for 'Select All', now opt for 'Copy'
5. Return to Arbtalk by your iPad/iPhone/iPod's menu button and opening the Arbtalk app - you'll enter where you left off in the same thread as before, from where you can 'Paste' the copied link, (URL) into your own post
Sorry for the confused first 'helping hand'!
Steer well clear of the oregon arboral as it eats away at the paint inside your oil tank and then the flakes of paint block up the oiler :thumbdown:and the only fix (for three) saws running the stuff was to split them in two and paint strip the oil tanks.
If cost is an issue then cooking grade rapeseed oil is fine and you'll have no problems with lubrication but over a prolonged period (years) the build up of associated gunk can become problematic - corrosive to oil pumps, sticks to cooling fins etc. This can be remedied by regular and thorough cleaning.
If cost is not an issue then the Stihl bio is good (made out of turnip oil amongst other things) and you don't get the same level of gunk build up and associated problems.
Corrosive.....how?
"Turnip oil"......I never even knew turnips HAD oil?
Have a gander through here:
http://en.m.wikipedia.org/wiki/Rapeseed .
Seems like the origin is the same and 'turnip oil' is just another way, if older way of naming rapeseed oil.
It was a lighthearted comment which if I'd have thought about what grows above ground on turnips would have instantly looked silly.
Well my small saw is running seemingly happy on turnip oil then!
