Just bought a new one and the oil flow adjuster moves no more than 9-11 o clock as you turn the screw. Is this normal? For a good range of adjustment I would have thought it would have more rotary travel than this.
Stihl chain oil also ok to run through this saw? Was told that I have to stick to XP for the pre mixing for warranty period but happy to put stihl oil through it for bar and chain.
Andy:confused1:
Edited by Taffyscouser
Andy:confused1:
Usually its about 9.00 to 3.00 o clock ?
Well started and ran it with the stihl chain oil and it was over oiling like a good in. Cannot turn it down past 11 o clock. So interested if anyone else has any variance on theirs with this screw setting. We have one with 9-3 o clock movement ( many thanks Stubby) any other variations or similarities with mine.
Andy
Andy:confused1:
Stihl oil is of course OK if you pick the right one - but I don't really see the point in using it (unless it has to do with the supply situation).
I would use Aspen premix anyway, for fuel.
Took it back today. Compared to three others on display and a 560 and they all had only two positions of adjustment . Maybe a change on the new models?
Baffled so just going to run it.
Get your dealer to phone Husky Technical and confirm . Might be a dodgy batch of adjusters ?
