As above leaking from under where oil adjust screw is, Is it a known fault? I've not stripped it down yet....
Cheers folks
Thread about exactly that a few days ago . Do a search its all there .....
Usually the rubber hoses that fit either side of the oil pump need replacing or a bit of a fiddle. If it is leaking without a bar on it, stick one on it and see if it stops - the tighened bar effects a clamping action on the pump:thumbup:
