rite read your posts i,am going to get something to eat been out all day splitting logs etc ive been and picked it up and will get some pictures up etc then with the help from you boys i can sorce a bar sprocket chain etc
  • Replies 55
I think the challenge is going to be identifying which, if any, of the currently available sprockets will fit.
Alec
Oregon do a book that lists saw manufacturer, model, chain options and what order numbers they are
Sent using Arbtalk Mobile App
just remembered someone wanted measurements sorry forgot to stick a steel rule near it etc has anyone got any info from oregon what bar/chain suits not so sure about the sprocket size but its 7 tooth
forgot again silly me its been sat under a tool bench for 25 years and the last time i had a look it was,nt as scratched up as its been stored with other tools/saws grinders etc etc but hoping to get it working again i allready know the engines good to go its just the bar/chain /sprocket thats holding it back i cant wait to use it like a little lad with a new toy lol
Edited by predator
They do, and it's also available as an online selection tool, but it only goes back so far (unless the book version goes back further?)
Otherwise there are several ways I can think of to do this.
The easiest would be to contact the people in Somerset referred to earlier. It's possible they know the answer!
It would be worth dropping Magnus a PM as he may well know the answer, and if not it is likely that he will know a man who can.
Gordon at Carlton Trading may well have original parts and if not he may well know the modern equivalent.
As a last resort, measure everything up - for the bar you will need to measure the following:
Diameter of studs
Spacing of studs (centre to centre)
Distance from back stud to clutch drum
Diameter of tensioning pin
Vertical distance down from centreline between studs to the centre of the tensioning pin
Horizontal range of travel of the tensioning pin, although this can probably be guessed at from the photos
For the sprocket you will need to take it off and measure:
OD of clutch drum
ID of clutch drum
Depth of clutch drum
Diameter of crankshaft where it passes through the bearing
Diameter of bore through the sprocket
Depth of sprocket
There will be some flexibility around the above, and some degree of bodgery may be possible, but starting from that it should be possible to measure up a few existing ones and see what's available.
Alec
i just checked with my father and you defiantley have a solo rex 125 the carburetor for the the 140 super rex is ahl 154a
some models had automatic oiler and hand oiler i will get somes pics of sprocket bar and chain tomorrow or tuesday
just been on oregon site no bars or sprockets :thumbdown:
OREGON®: Selector Guide so unsure about the chain aswell till i,ve sorted a decent bar/sprocket
it looks like i may have to modify a bar to suit thats not a problem to me but the sprocket chain matching going to be a pain me thinks
i will have a look tomorrow and i will speak to the man in somerset and he might have a bar lying around he done a chain and service earlier this year
THANKS I WOULD BE VERY GREATFUL
i havejust been rooting on the net etc and acording to some folk depending on build year some as already stated had 404 chain fitted but the sprocket is the problem i think as stated red sprockets a 7/16 i live in hope thanks for the help so far i,am hoping to fit a decent size bar on it and a regular chain size too so when if needed i can use it with care lol
SORRY FOR THE MITHERIN BUT????? what size bar should i go for i forgot to ask" as i,am unsure what a saw like this should use for the odd big lumps i get are around 3.5ft/4ft will this saw cope etc with say a 25/30 inch bar ?????
i also cant get over how many chainsaw collectors & museums there are some blokes have full sheds lol its very addictive by the looks i,am going to call this saw my muscle saw lol as stated in other forums the usa love old muscle saws i live in hope anyway thanks again for the helpful posts cheers
