I need an anti down draft cowl as Im getting some smoke in the livingroom and wondered if anyone has got a Dragon one that revolves out of the wind like in this link Darco Rotowent Dragon 150mm Revolving Cowl - Stainless Steel - NG Bell Building Supplies, Builders Merchants
It seems you can sweep the chimney without removing it like you would with the wirly go round types.
Any feed back would be much appreciated. :confused1:
Mini Eurocowl has solved all the down draft issues I have ever come across
Mini Eurocowl Chimney Cowl - Stainless Steel
Available from most good stove retailers, or me and it has a guarantee that says it stops down drafts or your money back.
I cant see that turning one doing a whole lot to be honest, might be wrong, never seen it before. Looks like its an interference fit only on 150mm and 200mm id pots. Have a wind like we are having here tonight and I have reservations about it staying put.
Eurocowl is stainless steel, terracotta coloured to match a pot and clamps to the outside of the pot with a hose clip.
A
