  • Replies 38
Meteor or hyway are the preferred, but golf or episan are alternatives, Chinese stuff can be hit or miss
Sent using Arbtalk Mobile App
Do you know any suppliers in the UK? be much appreciated :001_smile:
Personally I would try to rework the cylinder, I have had some pretty bad examples on my "Whats on my Bench" thread that have cleaned up and are giving good service. I have even had some cylinders that didn't look good but still made high compression.
The Meteor pistons are the best and Danikrop on ebay from Greece is a top guy - ordered a piston on Thursday midday and it arrived Tuesday - now that is better than many UK sellers - I have ordered around 30-40 pistons off the guy and always around a week or under:thumbup:
The guy called MaxMoto from Latvia is also reliable!
The weak point in the Chinese pistons are the piston rings and circlips:thumbdown:
By rework do you mean use a cylinder hone or such like?
Emory cloth, wd40 and elbow grease to remove the transfer, the cylinder is rarely scored so bad it can't be used, I've cleaned a 200t cylinder up today with that method
