i have got some chestnut and oak milled up today, hows it best to dry then out?
ideas please :confused1:
i know they need stacking, with small bits of wood between to allow air
any help / advice
my two pence worth... 3/4" is a bit big, I use 16mm, I know its only 3mm smaller but its a safer size when worrying about surface checks or in the worse case scenario mild case hardening, where the surface dries thereby preventing boards interior moisture to be effectively sealed in, caused by too rapid initial dry, caused by too much air movement , and the sticks@ the end of the boards should be within 2" as it helps to prevent end splitting, and as BJ mentioned, wt them down, having inverted the top sawn board which will help with the cupping issue and if possible cover with something non metallic.
