  • Replies 22
Look on Rob d's website
Chainsawbars.co.uk think there about £50 bud, great on longer chains.
Have you also thought about a file guide? Again rob sells them at £20-£30 I believe
The one to look at on chainsawbars is the Granberg precision grinder. Much better than hand filing and gives control of all angles, hook and tooth length so can recover uneven chains. It's not as quick at removing material as the bench type but can be used on the bar, and in the field.
Alec
I have a granberg precision grinder, which is really good except trying to find a good 12v supply
Sent using Arbtalk Mobile App
I have a lidl one £20 does everything I need. I would imagine if you spend more the pawl mechanism would be better quality and made in metal. I find my plastic one gives some engineers artistic licence.
