No the one on your single cab navara is the best!! It must be five foot off the deck of the pickup. It must hold the same as a mog lol
I took it off the double cab and stuck it on the single cab then extended it a bit. That's why it had a really high bit and then a low bit. Now it's just a low bit with a little roof return and sides that are much lower. Can't hold as much but doesn't look like a ship!
1" angle frame with 12mm phenolic resin coated ply sides and 9mm roof so it doesn't weigh much but holds about 6.5m2 :blushing:
Dropsides still drop down for loading timber and has a perspex window in the front with a hinged cover (so it doesn't get smashed) as it makes reversing the chipper easier.
Simples :biggrin:
Simples :biggrin:
[ATTACH]140062[/ATTACH]
Hay arbtech I really like what you have done there with your Iveco daily, I'm looking to getting one after Xmas being of new year and looking in going down the same route s your set up.
Would there be any chance you could put up a few more pics from other angles of your truck so I get a idea where to attack it from.
Regards doug
