Hi Folks,
Newbee here!
I went to replace my AV Mount on my 2010 Stihl MS441C to find out that there is two kits...1:-A standard "Soft" Kit and
2:- A "Hard" Kit. (For some reason, mainly used in US??)
Does anyone use a hard kit here in the UK??
Or does anyone just know what the pro's & con's are between using the two??
I imagine the hard will stiffen the saw up... which I would like....But not if it is going to be significantly harder on me!!!
I use my saw a LOT on Big hardwoods... Beech, Oak, Ash, etc... Yeah it's usually quite big stuff!!!
Any advice very gratefully received!
Thx.
Finners. :thumbup1:
Thx tree_beard..... I use a 16" bar a fair bit of the time for my smaller logging... and for the big stuff.... basically upto 50" beech, etc, the 25" bar gets used quite a lot!
I have had my saw from new... It was a bargain.... I would've liked a bit bigger, but had to get as big as I could afford and this popped up with loads of chains and bits & bobs. Someone didn't realise quite how fit one has to be to use a 25" bar all day! lol Anyway... became mine & was brand new!!
It Always felt "Floppy", even with the 16" bar.... Do you think i may find it better with the "Hard" mounts. (I'm a pretty tough cookie!), but just still don't want to be shaken to bits after a day of hard cutting! Well.... anymore than usual!!! lol
Thx tree_beard
The hard option is really for 'ax men' types with 36"bars on 70cc saws.
You might find they make the saw handle better with a 25". I dont imagine they would alter the antivibe noticeably... buy then ive never been that sensitive to saw vibes.
Isn't much in the vibes tbh, the 090 (hard) is only marginally worse than the 200t (soft), difference is, is that the saw doesn't sag on the mounts as much
Sent using Arbtalk Mobile App
