Ms260 fuel usage
Dorset Hedgelayer
evening all
MS 260 with 15 bar,
fully understand type of wood, using full bar length etc etc all make a difference
but what should be the rough/average length of time a tank of fuel should last . Say using to it max cutting full bar length
thanks
The fuel should run out leaving oil in the tank with the oiler set to full when both are full to begin with!
If you are concerned about the fuel consumption, get the carb set by someone that knows what they are doing:thumbup:
