I'm in need of a sprocket for my sawmill . It's 12 tooth . Diameter 70mm thickness 12mm
Have attached picture. Tried all the usual companies but no one has one . Can get from USA but just wondered if any one knows of any companies that I have not tried yet in the UK.
Cheers guys ImageUploadedByArbtalk1379958711.417535.jpg.d28abf38a22f186233a9fa38dbefffdb.jpg
Found them in USA for £69 . Fuelwood UK supplier not got the size I need .he is trying to get one at the moment.
But how much postage ontop.
This worries me as I was considering a Lucas. Surely all spares should be easily available?
Pop it into an engineering firm see if they can make you one up? Might be expensive might not be.
I needed a pin for a topper and it was over £115+vat for it. A £10 cat 3 pin and a £20 quid to a guy to put it through the lathe.
