Rebuilding long reach hedge trimmer head?
If it's the roller bearings on the cams its an easy cheapish fix just make sure the inside is completely degreased and spotless before rebuilding, if one of those little buggers is still in there you will have problems!
The others look a nightmare,and will need to be heated to remove.
Does any body know if the first gear that comes off the shaft that slides out when the pivot bolt is taken out is replaceable as a whole unit?
The gears are only available as a whole unit.
