how do you guys rate the fuji robin hedge cutters?
as its time for a new cutter....
it seems very light and powerful..
iv the old stihl 80 cutter.. but its been worked hard,
iv looked at the new 81 but it seems to be shrouded in cheap plastic
any ideas??? :confused1:
the new stihls are excellent, i use the type with the one sided cutter, the plastic looks naf, but is really strong and the new anti vibration is excellent, a pleasure to use:001_smile:
I use a single sided Echo HC341ES (1m blade).
I rate it farr better than either stihl or Husqy having used both, better starting and running and low very vibes. The blade deflector alone is worth its weight..... an expensive add on on the stihl and husqy!
we have got through loads of robin gear at work over the last few years!!! dont touch them they fall to pieces, now we have got a couple of the new still ones, the standard reach one with the long double sided blade is a top bit of kit, definitely worth the money.
thanks, im gonna stick with stihl,,, for the parts and servicing side of things..
shame they still didnt make the old hs80 24in as this was a top cutter..:sad:
