Hydraulic pump question
Marko
And that is the question... has it got an internal pressure relief system? If I put a feed to a log splitter from the pump and drop the return back into the reservoir it should be ok? I know a tractor has a pressure relief valve in its back end so nothing silly can happen and I really didn't want to power this up without one. Is it better to put in a separate pressure relief just to be sure?
That's unlikely to be a PR system and even if it were you shouldn't need it. Presumably you are going to connect this pump to a direction control valve on the splitter?
If that's the case the valve will have a PR valve built into it, well it ought to have anyhow. Lets see a picture of the valve to be sure
