Acacia planks
Vertigo Arb Ltd
Very true, but I was under the impression that you will get a nicer finish the longer you season it? True?
thats usually the case but after 6 months to a year it wont make much difference. the only problem could be stability with a mixture of wet and dry but 100% green work or 100% dry work should either be stable or dry at the same rate.
my large oak table (seen on this thread http://arbtalk.co.uk/forum/woodcraft-forum/60100-all-my-woodwork-so-far.html) and two benches was all kiln dried except the 6" table legs which were air dried for 3+ years so didnt move and the splits barely opened.
as far as asthetics go, just remember that beauty is in the eye of the beholder...
Yeah I think I'm going to spend the next few weeks milling everything and stacking it out of site somewhere so I forget about it!
Waste of time milling at tbe moment. You will loose more boards than u will probably get to keep. I know your keen, but wait till the right conditions allow for milling and stacking.
