- 0
If you're just starting out and you need business, equipment, tech or training support you're in the right place. If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom, then you're welcome too.
Question
castlemonkey
I was after some advice regarding a large mature sycamore tree that I have in my back garden. I have had it inspected by a tree surgeon and he pointed out to me a defect in the trunk of the tree which increases the risk of the tree failing in the future and suggested it was best to remove and replant due to the potential risk it posed to both my garden and my neighbours garden and property. I am reluctant to remove the tree as it is a feature of the garden and ideally I would like to retain the tree if it is safe to do so.
From what my tree surgeon said and from the research I have done through the internet, the sycamore is made up of two codominant stems with a tight V shaped union with signs of included bark between them but there appears to be no signs of cracking or decay at or around the join. The main trunk is near vertical some 45cm diameter and the other some 35cm diameter has grown at a slight lean to the southern light. The trunk at the base is some 65cm diameter with the union starting some 50cm off the ground. The included bark sections below the union are some 20-25cm long and 3cm wide on one side of the tree and 8cm on the other. The sycamore tree is at least some 15m high and has a crown diameter of a similar amount (15-18m). The tree is otherwise healthy, has a good shape, is in leaf, with little deadwood. No previous pruning has occurred to the tree it has been allowed to grow naturally.
The tree overhangs my two neighbours’ gardens/properties, and so as the landowner I understand I have some responsibility in ensuring that I reduce the risk that the tree poses. One neighbour’s house is some 20m from the tree, with the branches extending into their garden some 6m; the other neighbour is closer with their garage some 9m from the base of the tree although there is a drop in land levels of some 2m in-between. The crown of the tree extends to be roughly level with the edge of their garage.
I have attached photos of the tree showing its location, the 2 main trunks, and the included bark union from both sides.
I was wondering what was best to do with this sycamore tree.
From the photos is the diagnosis of included bark correct?
Is the tree safe / worth saving given its location, size, and defect?
If the tree is safe to retain what is my minimum requirements that I need to take to remove/limit my liability as landowner?
What are my best options with regards to pruning to limit the strain on the trunks?
Would it benefit / is it worth cabling or bracing the tree and if so what sort of cost is involved?
Given its current size and that it is some 50 years old already; how much bigger is this sycamore likely to grow?
I would welcome any advice that anyone can give.
Many Thanks.
Top Posters For This Question
6
7
2
3
Popular Days
Jul 7
12
Jul 9
7
Jul 10
6
Jul 8
4
Jake Andrews 6 posts
Le Sanglier 7 posts
Ollie Wall 2 posts
castlemonkey 3 posts
Popular Days
Jul 7 2013
Jul 9 2013
Jul 10 2013
Jul 8 2013
28 answers to this question
Register a new accountSign in
