Twisted Rope Help (Again)!
Trees-
Hi all,
I posted on here a while back about my rope being extremely twisted and was after some remediations. I tried a few ideas like walking it out-streched though grass, running it a few times backward and forward through a cambium saver, but nothing worked.
I've been working with it all twisted for a while now and I've got to a point where I get too pissed off limbing with it everyday!
Cheers fellas
How do you store your rope? Flaking is best to reduce twist. If you coil it do it in 8's, don't try to wrap it in ovals.
Do you use a figure 8 or Munter hitch? Both of them introduce twists to rope. Certain friction hitches have a habit of twisting rope too
To remove a twist that's there, I've found if you clip one end to something solid, then walk the full length out and pull and hold the rope stretched for 10 seconds or so, release gently, don't let it recoil, repeat 5 or so times it'll reduce the twist
Edited by Dan Curtis
