Higher level stewardship
So. One of the woodlands I manage is under a hls. So whilst complying with the hls we did the boundary clearance. Not taking away hedgerows. Just felling trees that have self seeded. Or are causing fence damage. Bearing in mind this bound is stock fence. Then dry stone wall. Then the woodland. Now the owner is unhappy!!! You just can't win!!! :thumbdown:
Good for you!
But surely that means that situations such as you've described above must be not that uncommon?
And even if that's never happened before, it seems like something that was bound to happen at some stage?
Maybe just sit down with mr Abramovich when he's back for a bit and explain that without clear "orders" this is a possible outcome.
Or...
If you're happy with the way things are running apart from this, just forget about it and stop moaning (I genuinely mean that in the nicest possible way, but after a long day shearing sheep and a few pints cleverer than average I lack the eloquence to put it any better).
