Actually Matt, they seem like sensible questions which may benefit other post readers. Though I would assume given the urgency it's a last min one off. A more specific location may sort the locals from those too far and save the op some time. Good luck if you make the call fella and I hope you find your man op.
There's quite a bit of "discussion" on the topic of answering potential job ads in the forum. If I was asking for help or seeking a temp sub, I'd prefer to spend a few minutes writing a clear, informative and comprehensive note describing my requirement rather than having the phone ring a hundred times from people that are either too far away or unsuitable.
You reap what you sow!
This is why i asked the questions.
I can follow instructions Matt however, as I live in an area with little signal and do a lot of work in the woods, if the guy is too far away or not looking for what I'm looking for there's not point in wasting his time on the phone if somebody else is trying to call.
I agree with you Kevin, there needs to be a standard format to follow, like on some forums for selling things, stating area job description, time scale and wages. Would make everyones life easier!
