Tractor front loader pallet forks
Scott Walker
Try a forklift hire / plant hire company. They often shift sets of forks after a specified time. Can pick them up cheap.
Be careful with this. Forks are generally moved on when they fail an inspection for excessive heel-wear or other damage and will no longer get a LOLER ticket. As forks are classed as 'lifting equipment' in the court of law - and they are of little use for anything other that lifting - then a cheap set could in reality turn out to be an expensive set.
Bargains are of course still to be had, just be careful.
Thanks for the heads up, phoned our local agri supply this morning and order a new one. :thumbup:
