Hi all,
Need a bit of advice please! I had my Landy 110 converted to a tipper before Christmas, using a secondhand pump & ram off a transit.
Yesterday I went to tip it and nothing, dead. Went back to the chap who did the work for me, and he reckoned the solenoid had gone after some prodding with some magic electrical device. He couldn't do the job, but recommended a commercial vehicle garage.
Went there, and they straightaway said they would bypass the solenoid with a piece of wire, and did. Got it home - now it tips, but sounds like the battery is flat? Eg slower than it was before, sounds "strained" if that makes sense. Also, once it gets to about halfway smoke starts coming from the wire they bypassed it with.
Was bypassing the solenoid a good idea? Or should they not have done this?
If it should have worked, why isn't it very happy? Wrong wire guage used?
I don't do electrickery :confused1:
Cheers,
Joe
Bypassing the solenoid will get you out of trouble but its not a long term solution. You need to replace the solenoid ASAP.
