Took spuds advice and used google.
Nylon is a hygroscopic material and if the line is stored in dry conditions, e.g. in a shed or a warehouse it can loose its moisture and therefore its flexibility, it can become stiff, brittle and break easily. Storing it for a couple of days in a closed bag with some added water at room temperature or higher will bring the line back closer to the original, more flexible condition and should significantly reduce breakage due to brittleness.
Wot I said, just more words.:biggrin:
  • Replies 41
