  • Replies 25
How do you find the 90 Stuart?
Do you have any problems with the bottom roller jamming with bits of wood.
Dean it does have that problem, i belive its due to the hydrulic pressure, i have had someone come out a few times before and adjust the ram on the yoke and the roller pressure.
dropping the flap underneath it helps a bit but you end up with loads of waste on the ground.
I have found that never opening the flap to empty the void under the feedwheel helps, the crap then hugs the wheel and doesn't allow any large bits in.
Still a pain in the rear IMO though, just a design fault.
Mines the 65XL BTW
