I dont know!
Are you supposed to wrap something round the tree and clip the hock to it
very basically...
you will need a strong webbing sling as and anchor for your pulley, the sling and pulley should have a higher working load limit to the cable or rope you use, the cable or rope should have a working load limit several times higher than the weight of what you are pulling.
the block in ty's link is for 10-11mm steel cable
  • Replies 42
I dont know!
If you read the link that Ty Unnos posted for you then you might have a bit more of an idea as to what you want and how to use it.
How much timber are you looking to extract? I see you are looking for a 20-22" saw and are trying to work out how to sell the timber.
just a bit worried you may be trying to tackle a big job with diy tools.
I dont know!
without wishing to be rude in any way it would seem that you are somewhat out of your depth and that what you actually require is some experienced assistance.
yes the block shown in the link is suitable for the application you have indicated and yes you most definately need a soft strop to go around the tree and secure the hook to it
cheers
mac
very basically...
There is no need for a high safety factor in a pulling operation
4x for lifting
2x for pulling - but this applies to the tension applied to the rope - not the weight of the object being pulled
safety factors relate to the applied tension - which is not necessarily the same as the mass of the moved object
cheers
mac
