The ovals are perfect for such a job- they load point to point. Simple additions of rubber bandits helps prevent rotation when not under load
I just found the steel ring on the dyneema rode up over the rubbers and everything felt a little bunched up on the O. everything has enough space with a flat topped crab.
  • Replies 23
Took a bit longer than expected but plumped for the spiderjack in the end I'm loving it although still getting used to making it self tend hopefully it doesn't take too long to get to grips with (no pun intended)
Sent using Arbtalk Mobile App for iPhone
Just make sure there is at least meter or two of rope below (you will do a lot more pulling your rope through) and pull the rope into the device.
