i am assuming the rope is changeable for any ten mm?
Apparently so but I don't think Ropetek will supply it with anything else, so it is up to you.
I seem to remember Paul Cox (inventor) saying on another forum that the 10mm Beeline fitted and worked the best. Paul and DMc would know more about this though.
It's also a bit smaller than it appears to be in the photos and videos.
I turned my sidewinder 90 degrees yesterday so that the zip tie clips are facing down and the rope exit is facing up.
It now sits much flatter on the harness and the lead out of the unit is better so rope in and out is smoother.
Brilliant!
Sent with my iPhone from me, to you!
Could someone please post a video or some pictures of it in use. It would be good to see how it actually works because i'm a bit confuzzled at the minute :confused1:
