Castrol oils
nicholiath
I've used castrol 2 stroke oils and find them fine. I used to find with some oils the spark plug would clog where as since running a semi-synthetic Castrol oil I don't get any problems. Just make sure it meets the spec the saw requires. I run mine at 40:1 as its not a Makita branded oil even though the spec is the same
