Get your waders on . then get in the stream put a rope on each end , up cut in the middle then pull the two half's to the bank you want . Get some help if needs be .
Pretty much what I was thinking but am not a pro Arb bod - the trunk will pinch the bar if you just try to cut from the top only - that was lesson 1 a few years ago:blushing::lol:
Lived to tell the tale:001_rolleyes:
