  • Replies 21
does anyone know how these liners will work with the aluminium mountain tops? ie...you have the option of having line-x sprayed up to the sides...or over the lip aswell. i like the idea of going over the lip but i am assuming this would interfere with the mountain to....anyone?
My Rangers got a Mountain Top which fits on top of the plastic load liner that goes up the sides and over the top lip. I think if the liner is sprayed on evenly it should be a similar mounting surface.
The tops got a rubber seal around it (similar to a door seal) which 'allows' for any imperfections in the liner. The only problem I've got is that it leaks when there is heavy rain (or recently snow) around the hinge area that does not have a seal on it.
Hop this informations of use.
Paul
