It weighs 4.5 tons - it would have to be a serious pallet!
I didn't find it too bad milling it like this - maybe if you had more than one to do standing them vertically would be the way to do it.
:001_smile:
Ok then not a pallet maybe a few sleepers :001_cool:
  • Replies 30
All things being equal I'll be doing something similar sized this weekend, and I do intend to stand it on end if I can. The down side if you're using a mill is that gravity won't keep the mill on the log, but in my case it's too big for a mill anyway so will be freehanding. I hope to get some pics for comparison.
Alec
Hmmm... now I'm thinking should I be milling vertically :blushing:
The only things that I thought may be a problem is the chain getting bogged down in the cut and the mill not staying against the flat surface...
That said the 090 should keep the chain going and after the saw is engaged in the cut someone else should be able to safely push onto the mill to keep it flat and the rails in contact with the log....
Ok you've convinced me - if I can get it vertical I'll have a go milling it vertically :thumbup: would certainly make it easier on the arms. I could stick the forks up above it and lower the mill into the cut to get it started.
Has it "dulled" the chain much?:o
Sent from my GT-I9100 using Tapatalk 2
Not too bad but there was a lot of grit at the end where the log had been dragged.
:001_smile:
Alec
Shame your not bear Sussex we can cut just under 6' on our new mill it's a beast
http://Www.Copfordsawmill.co.uk
Follow us on Facebook too
Alec
:thumbup:
Big lump like that why not quarter cut it?
It's a good point and I will be getting some quarter bits out of it but half is going to become a large chainsaw carving... sorry Bob meant to call you the other day but got side tracked :blushing:
That's a fair old mill but this lump still wouldn't fit - it's 7' across!
Alec
