tooth setter
marj
Hi,
Does anyone set their own teeth on their band mill blade? if so whats a good one?
I've got a couple of blades that are leaving a line, even after sharpening, so a tooth must be out. I'm having trouble finding anything online that's not in the states or really expensive.
Thanks
You will be wanting one of these, £2 from a car booty. I think that Clifton design in Bristol have tooth setters in stock
arent this size setters for hand saws? I can't see how they would work on a large band because they clamp the blade and have should enough room to push
the tooth and not just used as a pair of pliers.
