Just a heads up.
Trying to gain a bit of background before contacting Petzl.
We mainly use the double handed ascender as part of our initial srt access backed by hc & hitch.
Before moving over to Drt to work. (leaving the patron in place as a secondary emergency access line)
The ascender gets changed around each and every time to make sure that both sides get used.
The wear is on bothsides.
I had to pop up to the top of the oak we were tickling recently & noticed that the patron was getting glazed by the bottom of the right hand side yellow plastic hand grip on the Ascentree.
Has anyone (if used) noticed this themselves?
We're going to go down the route of not using the central krab hole (as It looks as if this is the cause of squeezing the rope on to the plastic) and using the two alternative holes instead with krabs or mailons.
Thoughts please?
  • Replies 24
Popular Days
In the long term I think we will start using the two side attachment holes(probably a couple of tapes & mailons) but in the short term will just alternate with a single rh & single lh ascender.
If you look at the both the lh & rh single petzl hand ascenders (which in essence the double handed one is) the main attachment hole is machined in a different position.
But this creates wear/glazing on the line
Have you noticed any on yours?
Nope and trust me my regular access line is donkeys years old, can you post pics of the glazing?
how bad is the glazing.
Not enough to retire the line/fail Loler examination, but enough (from the perspective of this semi retired climber) to warrant investigating a potential design issue that places the rope against an abrasive surface & puts wear on the life line of my teams climbers.
Well it looks like you have not used the single ascender much in time you may notice the same wear on these to, and maybe not depending on how you push up the ascendor.
