It's still just one at a time for me. I want to load up a saw horse and cut a load in one go. Save a shed load of time and fuel.
Sent using Arbtalk Mobile App
But with the thing in the vid, there's no loading to do - the action of cutting with that one is similar to the loading of yours and you don't need to pick up a saw at all, just crack on cutting and letting the wood fall into a barrow etc.
I'm not saying the one in the vid is safe, but it's certainly effective.
I agree it's effective just cutting and dropping into a container saves having to pick up your logs. To make it even better if the saw over hangs the container that would guarantee the logs fall in the container. I like the idea of the wood weight and gravity making the cut.
The other thing for me is each log takes a cut to create. If you can load up a load of logs one cut creates lots of logs.
