walnut question
alex_w
Hi,
Taken down a walnut today which was leaning on a wall. Have not cut the trunk off yet so not sure how much heartwood there will be. Have read that the stump is good for gun stocks but how much trunk, or how high above ground do you cut it?
thanks
Alex
For the best twiddly grain for gunstocks you're best digging the root out :001_tongue:
I suppose as stocks aren't very long you could get away with doing a high felling cut about 18ins to 2ft up from ground level, and then digging and tweaking the rootball out. You've then got the sweep of the major roots running up into the stem to give the curve through the pistol grip....
FIGURED GRADES OF GUNSTOCKS
How're things with you guys? Hope you're all well and busy, WW
