Looking for a ring.....
Rich2484
I'm looking for the petzl ring. It's on the sequoia harness to join the bridge to it. They have tHe removable bit that allows you to feed the webbing into it. It's not for my harness but rather needed for general use. Like being able to move it onto different areas of the harnes for tools.
Reason is a climber has been using the tree motion harness and the part he had the chainsaw on came apart so the saw fell... Not a good look. After looking at mine and realising that the rings could be used on the motion harness to attach to the webbing that is a lot stronger than anything else on it. Plus make wear lees apparent on the webbing when using carabiners.
Anyone know where they are available to buy. Tried ebay and jones but can't see them.
You can't buy them. Individually, they have no ce mark, only as a whole harness, so its not possible to sell them in the UK. You can replace them if you send the whole harness off to Lyon, through a dealer ie jonsies.
So for your use, it doesn't look viable
Sent using Arbtalk Mobile App
