So it can drive through a puddle :001_tongue:
A 4x4 needs to have low box for pulling and shoving big trailers up steep drives as well as ragging privet hedges out abd tree trunks up slopes.
And....?
The Nissan has a lo box:confused1:
  • Replies 58
it does ??
oh, must get one, it's bound to out perform the defender :sneaky2:
of course it will out perform the defender. It's not hindered with a green oval badge.
Just had a closer look at the photos and it doesn't look too bad, possibly might have a problem with stability like the defender did with a full load high up beofre I put the wheel spacers on.
Looks beefy enough though :001_smile:
Hi guys built my body myself and it is the bollo#ks
first made the frame then weld a 3mm thick one piece skin of sheet steel on the inside so everything slides out real nice.frame completely indipendant to drop sides, so they can still be used
this was then all sprayed with hammerite type paint of course
then on the outside i used a material called DIBOND a alluminum /plastic whith can take a print on it and is strong as anything the result is mmmmmmm sh*t hot will post pics tomoz
