mini digger problem
brian123
I may be wrong, BUT...
I think your machine is in fact an Italian built IMEF MX14-1, re-badged as an SMC which was the tracked excavator arm of Sandhurst Equip who bought the Smalley brand back in the 90's.
As mentioned, generally on this size of excavator if you strip the cab out you will find a panel bolted in that you can remove and struggle like hell through for access to the engine.
I wouldn't be surprised if the starter motor and various other service items were also accessed through here.
If you are struggling, the best thing you can probably do is ring Sandhurst Equipment in Kent and tell them the craic.
Good luck!
Edited by tommytopsoil
Spelling correction
