hi everyone,
as per title realy, i need 4"-6" squares or boards in both species for turning skittles. it must be completely seasoned and free of splits, spalting and too many major defects. i'm happy to cut out a few bits of knot or crack here and there as im well aware that with timber that thick it is only to be expected that there will be a few flaws but it still needs to be pretty good stuff.
if anyone has any or knows any one who does i would be happy to buy it.
any help is appreciated...
i can be contacted on 01628 666191 or you can email me through the skittles website (below) or PM me a message
thanks
Steve
hi everyone,
thanks
Steve
I may have some in I think 4" air dried for 2 years - but to be fair to get the thickness you are after fully dry is going to be tough to find and if you can find it will be expensive... drying anything more than 3" is time consuming, expensive and can easily end with defects that then makes the timber unusable.... hence the difficulty in sourcing it!
If it's a long term business making skittles I'd say buy the timber green in the thickness you want and then dry it yourself - you could buy green beech in that size for £12 a cube if you collected....
4" in which species???
how much?
i know its dificult to find the wood hence my asking on here, i've got quite a bit green cut and drying but it wont be ready for a couple of years. in the mean time i need some to be getting on with.
i managed to get a couple of sources and have been paying £20ft3 max.
the boards often have defects in them and as the pins are relativly short at 10-12" these get cut out.
perhaps i should have said free of split all over the place as i expect one or two good sized cracks even from big trees and as i said i cut round them.
if you ever come accross any please let me know
