Dimensions of Oregon small and standard rims please?
I'm being a 'tard.
Does anybody have the inside hole measurements for the two sprocket rim sizes?
I need one, and I'm pretty sure it's small but I want to check before ordering. The only other ones I have to compare it to are the same size...
:blushing:
Could be wrong here but the best way to check is read what it says on the existing power mate rim . i.e. .325 7 pin . or maybe .375 7 pin . ( 3/8 ) . if you go up to say an 8 pin its the outside dia that will increase , not the I.D. . .325 crank shaft dia is smaller than 3/8 or .404 but without getting up from my chair and taking a saw apart and measuring I can't tell you off hand . . . sorry had a couple of beers .
