What impact will this increase of salt being spread on our roads (due to the snow) have on trees?
Can we expect a lot of roadside trees to die due to reverse osmosis?? or to be an easier target for fungal pathogens as they will be under a lot of stress?
Any thoughts/comments welcomed :001_smile:
I used to work for Leicestershire county forestry Dept
we did a lot of work on the M1 in the Early 80s Planting in winter & thinning out in the Summer
we found that the closer to the road the more dammage
The salt used to burn the trees and then kill them
these where all young trees, the Mature trees did not suffer as much
Gritting with salt is just one of the many problems facing urban trees.
The fact that we have seen a bad winter, from an gritting point of view, will probably have an adverse effect on a number of street trees, however, I suppose you could balance that up with the fact that the cold snap kills off a lot of pathogens. Maybe?
I could imagine it could be more of a problem in the south of the country. In the North West the gritters are out alot normally anyway so don't think it will do much up here. I do think the colder winter will be better as it does help to kill off pests and diseases. A lot of diseases are blamed on the warmer winters we've had over the past 10 years or so.
